wireless power transmission transistor problem
Discussion in 'General Electronics Chat' started by Jason27, Nov 16, 2015.
  1. Jason27
    Nov 15, 2015
    32
    hi all new user, doing a project with wireless transmission with a circuit i fond on the net, problem is the transistors get VERY hot in a few minutes, the only difference is that in using 5w instead of 3w resistors. any help would be appreciated
  2. Bordodynov
    May 20, 2015
    670
    194
    Driving experiments very bad. Emitter junction are punched. There is a gradual degradation of the transistors. Necessary protective Schottky diodes.
    cmartinez and Jason27 like this.
  3. Jason27
    Nov 15, 2015
    32
    thank you very much for your help and reply Bordodynov, ill try your circuit, what wattage resistors do you recommend?
    do i need to change the pickup coil at all other than 60 winds? or anything you may think i need to know as I'm only learning here.
  4. Bordodynov
    May 20, 2015
    670
    194
    The calculation gave 1.33 watts. I recommend at least 2 watts.
    The number of turns of the coil is determined by the geometric dimensions and the desired frequency of operation. In my model of the transformer inductance of the coil is determined by the number of turns and the inductance of one turn of "Al".
    Say what you design (geometry) and on what frequency you want to work. Then I can make a more accurate calculation.
    2.34 watts, which dissipates much transistor is heated. Perhaps the MOS transistors are more acceptable.
    Jason27 likes this.
  5. DickCappels
    Aug 21, 2008
    2,758
    667
    Hey wait...something doesn't look right. In most places these things operate between 13.56 and 13.57 MHz so as to not interfere with radio services. The 2N3055 is not fast enough. any kind of high speed use. It is quite likely that the 2N3055's don't ever fully turn off. Try faster transistors.
    By the way, the wattage rating on resistors tells you how many watts you can put into them. For example, a 220 ohm 3 watt resistor will dissipate the same power as a 220 ohm 25 watt resistor in a given circuit.
  6. Jason27
    Nov 15, 2015
    32
    What transistors would you recommend DickCappels?
    And thanks again for your reply guys
    Loving the learning.
  7. DickCappels
    Aug 21, 2008
    2,758
    667
    I cannot recommend a transistor for your application because there are too many unanswered questions about the application and circuit, and in particular the transformer, which is the (no pun) core of the circuit.
    The circuit, while not incorporating best practices, is known to work, and was proven by @Bordodynov. Maybe if you can tell us something about the transformer somebody can make some suggestions., or maybe better, give some advice on the transformer you don't have any more information to share about it.
    Jason27 likes this.
  8. Jason27
    Nov 15, 2015
    32
    Yes, I understand your point, the information and help you guys have given me for this project is ample and appreciate the time given, thank you
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    The only thing limiting the current through the transistors is the transformer impedance. To know that we need the inductance and frequency.
    ak
    cmartinez likes this.
  10. Jason27
    Nov 15, 2015
    32
    To tell you the truth @AnalogKid I'm not very educated in electronics yet(but I'm learning) so maybe you could suggest a method for me for the wireless transmission coils! I now have the above circuit working kindly given to me from @Bordodynov and have it working a 12V Duratech 80mm computer fan with a current draw of 0.02A.but the transistors are still getting very hot still. tnx.
  11. Bordodynov
    May 20, 2015
    670
    194
    See
  12. Bordodynov
    May 20, 2015
    670
    194
    I added to the electronic circuit two capacitors. Efficiency has increased dramatically. Also added a bridge rectifier. I'm also more accurately simulate the output winding connection to the input. In my opinion if you take faster transistors, it is possible to increase the frequency up to 455 kHz and use one coil turns.
    See
  13. Jason27
    Nov 15, 2015
    32
    fantastic, thanks @Bordodynov I've already added the the bridge rectifier. ill get the caps asap. it seems to work well now that i added the schottky diodes so i can't wait to see the new results.
    do you know how to make a hall effect latch(i think thats what i need) for a 2 pole motor electromagnet (pic below) i have a AST117 hall ic from a computer fan and wish to power the electromagnet. for the same project? i can find circuits but i want 12v not 9v like i can find.
