Wireless Power Transfer
Discussion in 'The Projects Forum' started by Furqan Haider, Jan 15, 2016.
  1. Furqan Haider
    Jan 15, 2016
    16
    Hello everyone. I have a project of Witricity and i made a wireless mobile charging in the shape of Witricity. Although i have already done with my project but i implement it on from 4-5cm range but i want to transfer this power from some more large range i.e. 1-2 meter. Please guide me that how can i made this possible. How can i charge mobile or run any appliance from about 1-2 meter ??
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    Why?, whats wrong with a charging lead..
  3. Furqan Haider
    Jan 15, 2016
    16
    There's nothing wrong with any component. The thing which i just want to know that how i can implement it from 1-2 meter. Whether i increase the no.of turns on transmitting coil or anything else? Guide me!
  4. Dodgydave
    Jun 22, 2012
    5,142
    768
    Bigger coil, bigger rf transmitter, bigger power consumption, just to charge a phone seems ridiculous to me.
    thumb2 likes this.
  5. GopherT
    Nov 23, 2012
    6,303
    4,019
    you want to go from 5cm to 150 cm. That is 30x the distance. So, you just have to use the 1/d-squared law. In your case, 30 squared is 900. Use 900x more power than your first project.
    You may need bigger diameter wires in your new project.
  6. nsaspook
    Aug 27, 2009
    3,009
    2,352
    The flat truth about 'wireless' power. It's not easy to move beyond simple near-field induction. People are trying just about everything under the sky but I'm skeptical of wireless power in a room sized space for anything more than milliwatts is practical under current inverse square law physics unless some version of directional beam forming is used.
    http://ubeam.com/
    These guy are using ultrasonic energy.
    GopherT likes this.
  7. Furqan Haider
    Jan 15, 2016
    16
    Ohhh you mean that i just increase the number of turns on Tx coil ?? Actually i used 36 turns receiving coil and 10 turns transmitting coil in my first project.
  8. GopherT
    Nov 23, 2012
    6,303
    4,019
    No, turns are not equal to power.
    I am saying that if you put 10 watts into the first project, that you will need 9000 watts into the new project.
  9. Kermit2
    Feb 5, 2010
    3,845
    963
    Creating a matched resonance between the coils can increase the distance over which power can be transmitted.
    Have you got the proper equipment to determine your inductance and calculate the resonant frequency?
  10. Kermit2
    Feb 5, 2010
    3,845
    963
  11. Furqan Haider
    Jan 15, 2016
    16
    yes my both coils frequencies are matched with each other that's why i implement it successfully but now i want to run it at a range of 1-2 meters. how do i do this?
  12. Dodgydave
    Jun 22, 2012
    5,142
    768
    Hey why bother charging a phone using approx 5W of power from the mains with a lead, just use a kilowatt instead with wireless charging,!!! :confused:
    way to go Asia, world leaders in CO2 emissions....
    thumb2 likes this.
  13. nsaspook
    Aug 27, 2009
    3,009
    2,352
    Resonance only solves the impedance matching problem for better coupling of near fields, it doesn't solve the basic radiation or resistance loss problems.
  14. Furqan Haider
    Jan 15, 2016
    16
    Sorry mate. I can't understand what you are trying to say. Just show me a map that how can i use kilowatt or some big power ??as one fellow says that upto 900W will be used for my desired thing.
  15. Brevor
    Apr 9, 2011
    282
    56
    Im thinking there may be a way to do this using a magnetron tube, it may also win you a Darwin award too.
    thumb2 likes this.
  16. shteii01
    Feb 19, 2010
    3,500
    511
    Can you say Tesla Death Ray?
  17. nsaspook
    Aug 27, 2009
    3,009
    2,352
    Update: https://techcrunch.com/2016/05/11/charged/
  18. Papabravo
    Feb 24, 2006
    10,340
    1,850
    He is saying that the minimal efficiency of wireless power transfer makes it impractical for real world tasks. He is saying, in literal terms, that to get 5 Watts of output power may require an input power of 1,000 Watts for an efficiency of 0.5%. In my estimation that would hardly be worth the effort.
  19. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    Separate from the dismal efficiency as a power transfer device is the excellent efficiency as a broadcast noise device. At 1000 W or 9000 W, 99% of the energy into the transmitter will turn into radiated noise that disrupts radios, TVs, and phones. This is guaranteed illegal.
    ak
  20. tcmtech
    Nov 4, 2013
    2,107
    1,747
    More to the point what is your present power transmitter circuitry designed as and what frequency are you using?
    The next step is to basically make the same circuit that will operate on the same frequency but with a far higher power capacity.
    Personally, some years ago I played around with wireless energy transmission using basic Tesla coils and their original designs as Tesla himself documented them. I had no problems with transmitting ~20 watts up to ~20 feet with only 100 - 200 watts of transmitter coil power that ran off a 15 KV 30 mA neon sign transformer and a spark gap.
    The big trick is how to design a secondary coil set to the receiver coil that will allow for the primaries high-frequency high voltage power component to be down-converted to a lower frequency and voltage that can be easily rectified and converted to a usable DC power.
    So I say it's totally doable. You just have to know how to get your energy back out of the system to make it work.;)
