Wireless modules and time sync
Discussion in 'Wireless & RF Design' started by gotumal, Mar 20, 2009.
  1. gotumal
    Thread Starter Active Member
    Mar 24, 2008
    99
    Dear Reader,
    In my project, I need to have highly precise time syncronisation between two modules (in µs). I am not supposed to use any wires in between. So I was looking for wireless devices like RF or IR modules. I need timley delivery of message in micro second. I am not worried about so called latency time since I can start my communication in advance. But after that, any data (few bits) sent should happen in few hundread nanoseconds.
    I don't have any experience in WLAN or IRDA. But I beleive IRDA and WLAN are meant for accurate data and not timely delivery. Viz. it will take it's own time to send the data (even the speed is in Mbps) and I don't have any chance to interfere at low level drivers in that protocol stack.
    Is that so? Is there any other dimension what I am looking for?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Some further detail is necessary. If you send data to a receiver, it can pass with nothing more elaborate than a shared carrier frequency. I have been around suppressed carrier data links, where it was necessary to enable the carrier in order for one of the receiving stations to get synched up.
    Ordinarily, a radio receiver just waits for input. When a carrier is detected, the squelch circuit indicates activity. That can be the wake-up for you data receiver.
  3. gotumal
    Mar 24, 2008
    99
    Thanks beenthere for your reply.
    Here, two modules kept apart need to do "some activity"; almost simultaniously. The max differnce could be 5 µs. So to initiate this ativity, one module has to inform that it has started. I don't want "wake up" time by a squech ciruit be in picture.
    So, if the carrier has already been detected and some data communication is happeneing already, say a bit stream of "1010" continuosly. And now if I trasmit say "1001" indicating the sync. Will reception take place in 1µ if the datarate for the wireless module is 4Mbps?
    Thanks for your time again.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    4 bits at a 4 meg rate should go in 1 uS. The only delay is the speed of light delay between the transmitter and receiver.
    That would be accurate for a direct RF link. Dealing with WLAN, your data gets placed in packets and transmitted through a larger network. I am not at all sure that the degree of packet transmission latency can be predicted. There will be the time necessary to form the packet for transmission and unpacking it at the receive end.
    Using an IR link avoids packaging the data into packets, and gives a predictable data rate, if limited range. IRDA does support the 4 mbps rate (unless the protocol forces some overhead by doing CRC checks).
  5. gotumal
    Mar 24, 2008
    99
    Thanks beenthere.
    I would order two IR modules and start doing the xperiment! :)
