Wireless Headphone cutoff
Discussion in 'The Projects Forum' started by OberSchutze, Nov 13, 2012.
  1. OberSchutze
    Nov 13, 2012
    5
    Hello, I am trying to make a small keyfob type wireless relay that will connect to a headphone jack to cut out the audio when the button on the keyfob is pressed. Has anyone ever seen one of these or have a place where I can look to build one from scratch. Thank you for your time.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Sure.. There are TONS of keyfob controlled relay modules on ebay (starting at only a couple dollars and going way up based on complexity/need,etc..). Just use it to disconnect one lead of the jack.
  3. OberSchutze
    Nov 13, 2012
    5
    But don't those relays have a output voltage?
    EDIT: Also I cannot buy things off of EBay.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    A relay requires power on the "coil" side and then can switch signals (like an audio signal if needed or a light/motor,etc..) on the "contact" side. They are "dry" contacts in that no voltage is present ..ie no output voltage using your terms.
  5. OberSchutze
    Nov 13, 2012
    5
  6. OberSchutze
    Nov 13, 2012
    5
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    Is amazon or any of the other hundreds of sites on the internet that carry these out of the question too?
    No need to spend over $20 USD for your needs.
  8. OberSchutze
    Nov 13, 2012
    5
    I work for the Navy and they have strict buying requirements.
