Wireless gimbal project using rx/tx & servos
Discussion in 'The Projects Forum' started by pityocamptes, Apr 14, 2016.
  1. pityocamptes
    Jul 25, 2012
    I need some help making a wireless gimbal. I assume code is involved. I would need help with code and schematic.
    Basically I have made a headtracker that I want to use to control a wireless gimbal assembly. I assume the headtrackers PWM signal wire needs to connect to the tx unit.
    Looking to make a project that does the following:
    1) Able to bind the rx/tx together so no interference from other similar radio freq.
    2) Tx needs a button when pushed activates a relay on the rx that controls power on/off
    So i assume it would be a three channel rx/tx? One for pan another for tilt and another for the power relay?
    Any help gladly appreciated. I would also be willing to make a donation for anyones help. Thx.
