Wireless Electricity ( MOSFET issues)
Discussion in 'The Projects Forum' started by Atom96, Dec 8, 2012.
  1. Atom96
    Dec 8, 2012
    SO , i am trying to transfer electricity using resonating frequencies of about 50 - 60 KHz . So my whole setup is based on a zv flyback driver.
    Based on this project :
    http://www.instructables.com/id/Wireless-Ipod-Charger/
    I have made the complete circuit on a breadboard but the mosfets don't function properly . This happens : Over a power supply of 16 V DC at 1 A one the mosfet over heats and the other one remains cool as if not turned on . I suspected it to be faulty so i swapped positions the same happend with the one i replaced.
    Primary coil 9 + 9 turns seconary coil 17 turns .
    I used a 2 uf mkp cap , an inducer with about 30 turns and was able to get an output of 5 v at receiving end at a ditance of about 10cm. (with the over heating problem)
    On my second attempt i rewired the cirucit using 1 uf mkp with indcuer of about 45 turns and with the same circuit the nothing properly worked the mosfet kept on over heating and using my multimter i noted that the voltage i got at the pimary coil cap was only .25 v ! .
    input was with 16 V without load but when i conneted it to the curciuit staring voltahe only read 5.7 V ! what happened to those 16 Volts .
    I want to know
    . why does one Mosfet overheat and the other one reaming cool.
    .Why am i having such a huge voltage drop at the starting point + and - terminal of the primary circuit
    Finally the circuit does not work.
    I am attaching the citcuit diagrams.
  2. Atom96
    Dec 8, 2012
