Wireless door sensor
Discussion in 'The Projects Forum' started by bavman, Jul 20, 2011.
  1. bavman
    Jul 20, 2011
    I want to build a little fun "security system" for a couple doors in the house just to try stuff ive been learning. I have a board all wired that trips an alarm when a door is opened, but im having trouble finding an actual wireless sensor. The doors are too far apart to be running wires all over my house.
    I would like something really simple what will transmit either a high or low signal to my board depending on the status of the door. Im having a bit of trouble find one online. Thanks for all the help or input in advance.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
  3. iONic
    Nov 16, 2007
    1,422
    68
    No doubt, you will have to do some modifications to make the door chimes work and the signal range may not fix your requirements.
    I suppose if you have already built one unit that works for one door, you could always just build another for the second door!
  4. castley
    Member
    Jul 17, 2011
    31
    you can buy a wireless doorbell. place the sending battery-powered push-button so that the toor will momentarilly activate it.
  5. peter_morley
    Member
    Mar 12, 2011
    179
    At radioshack they have a 38kHz IR sensor and they also have a high power IR transmitter LED. You could get a 555 timer and set the frequency to 38kHz which would drive the IR emitter LED. Place the emitter and detector across from each other very close to the door. Whenever the door opened the detector wouldn't receive a signal because the door would be in the way and then you could activate the the bell. Not sure if this would be something you could do for your application but its a nifty little circuit and it introduces you to IR transmission which is fun stuff. :D
