Wireless cable (analog) TV transmitter circuit
Discussion in 'Wireless & RF Design' started by Willen, Sep 6, 2016.
  1. Willen
    Nov 13, 2015
    141
    12
    First question is why analog cable do not radiates in the air even if I connected a sort wire (as antenna) to the core wire of cable TV? Yes it radiates few inches poorly or TV receives poor signal if I did so. Does it mean the signal of cable TV is so low to transmit in the air?
    Main question is, to transmit cable TV in the air such devices available : http://www.aitech.com/products/wirelesscabletv.htm But I am not getting simple version of toy cable TV transmitter 'circuit' around internet easily. There are just TV modulator (transmitter) available.
    The highest channel of my cable TV has 855MHz so I think I could experiment with few of S9018 (1.1GHz) transistors if I could find guidance circuit.
  2. wayneh
    Sep 9, 2010
    12,388
    3,244
    I'm no expert, but yes, the signal is far too small.
    I don't understand the question. What's wrong with the commercial products? What are you looking for but not finding?
  3. crutschow
    Mar 14, 2008
    13,501
    3,374
    You probably can't find simple circuits because broadcasting the whole wide-bandwidth cable TV signal is likely illegal.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    Edit post #3 - completely illegal, even at 29,000 feet.
    ak
  5. Willen
    Nov 13, 2015
    141
    12
    Probably it's not illegal to transmit around a room.
  6. crutschow
    Mar 14, 2008
    13,501
    3,374
    But how do you confine it to the room, unless it's a screen-room?
  7. Willen
    Nov 13, 2015
    141
    12
    In my FM toy transmitter experience, a general purpose BJT OSC with 3V transmits just around room without antenna connected.
    I have an experience of jamming TV of my home too when I turned ON my DIY and poor man's regenarative FM receiver. I did't used that one any more.
  8. Sensacell
    Jun 19, 2012
    1,183
    276
  9. crutschow
    Mar 14, 2008
    13,501
    3,374
    Sensacell and Willen like this.
  10. Sensacell
    Jun 19, 2012
    1,183
    276
    My bad- misread the post.
    How about a "distribution amp"?
  11. Willen
    Nov 13, 2015
    141
    12
    Thank you sensacell, but for this moment I do not want to use professional devices. I just want to experiment and see. So I want to play with DIY circuits.
  12. crutschow
    Mar 14, 2008
    13,501
    3,374
    Unless you've had some experience with wide-band, high-frequency circuits, good luck with that. :rolleyes:
  13. Willen
    Nov 13, 2015
    141
    12
