Wired And
Code
Joined Nov 29, 2005
here's a little question about open colector and wired and.
vcc
R
----------> output
Out = X Y
Question:
the output will be true when the circuit is closed (as in the figure) with the ground connections "closed". Is that correct?
Is the following correct?
- when they are all unconnected they dont send the 0 from the ground so the output gets the 1 from the Resistance
- when they are all connected they all send the 0 from the ground so the output is 0 because 0 goes above 1 in OC
- when one is connected it sends a 0 from the ground and the output is 0
Thanks.
beenthere
Joined Apr 20, 2004
15,819
If you're using positive logic, than your two switches make a wired NOR function. The output is true wuth neither input, and is false if one or both is made. A OR B = notC.
Gorgon
Joined Aug 14, 2005
113
Originally posted by Code@Dec 9 2005, 05:50 PM
Out = X Y
Question:
Thanks.
[post=12334]Quoted post[/post]​
This is an AND gate. The function is Out=X AND Y.
If both X AND Y is connected then Out is high(+V), and only then!
TOK ;)
