I need help implementing a wired-AND bus for a serial pin (MISO pin on a SPI bus). The MISO (Master in/Slave Out) line comes from 3 different devices and there is a pull up resistor on the input to the Master device which is reading the MISO line. On the current schematic it shows the 3 MISO pins from the 3 slave devices connected directly together then sent to the master device board, but the bus isn't working and I'm wondering if the connections are wrong. Anyone ever done a wired-and bus before? Any advice?
