wire wound resistor
Discussion in 'General Electronics Chat' started by matty204359, Aug 27, 2012.
  1. matty204359
    Apr 6, 2011
    105
    Does any body have an idea what kind of wattage this resistor can take? the wire appears to be about 16 gauge(the wire has a diameter of 1.01 mm according to my dial vernier) and has a resistance of 11 ohms. I don't know the length of the wire.
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    Just guessing based on the physical size, I would say 100 watts or more. You can count the turns and measure the diameter to get a close idea of the total wire length. Then, you could use that with the total resistance to know the resistance per inch, and then correlate that to what the composition of the wire is, and then get a better idea of its rating.
    What does the wire seem to be made of? Could it be nichrome? I wonder if it was built to use as a heating element.
    matty204359 likes this.
  3. mik3
    Feb 4, 2008
    4,846
    63
    I would say 500W for sure!
  4. cork_ie
    Member
    Oct 8, 2011
    348
    58
    Looks like a cut down element from an electric heater.
    These normally glowed bright red . They were about 14" long and 1KW.
    while it would probably tolerate 500W
    I would say c. 100W is more like the intended limit
  5. matty204359
    Apr 6, 2011
    105
    excellent, it will be a good dummy/test load! I don't know how to tell if its nichrome wire. I measured the diameter and it ranges from 1 3/8" - 1 7/16" because its not perfectly cylindrical. it has 61 turns with a circumference of 4 1/3" - 4 1/2". giving me a wire length of 264 1/3"(33.9 milliohms per an inch). - 275 1/2"(39.9 milliohms per an inch). Does anybody know what nichrome's resistance per an inch or foot is?
  6. matty204359
    Apr 6, 2011
    105
    sorry 18 gauge is the wire thinckness. I've tried google, I'm not having luck determining the resistance per foot/inch of 18 gauge nichrome wire.
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    18 awg nichrome is .422 ohms per foot, which translates to .035 ohms per inch.
  8. matty204359
    Apr 6, 2011
    105
    that fits great with my estimated 33.9 -39.9 milliohms of resistance per an inch.
  9. tracecom
    Apr 16, 2010
    3,879
    1,396
    So, it is quite likely 18 awg nichrome. I agree with cork_ie that it is part of a heating element that has been cut down for some special purpose - maybe a dummy load for something, or maybe a heating element for some specific voltage. Ohms law will tell you how much current it will conduct at various voltages.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    You've probably realized that nichrome comes in different diameters for different purposes. In my clothes dryer, there are 2 diameters, one for 1800 watts and one for 5000 watts. I'm sure there are several more sizes.
  11. matty204359
    Apr 6, 2011
    105
    indeed, when trying to find the resistance for the gauge wire I have, I found a nice table with the gauges and amperage for different temperatures. I have learned much about heating elements. however I doubt I'll be using this thing for a heater any time soon, I'll use it as a dummy load in my higher power circuits.
    I got it along with several other things from a friend who was into electronics. He recommended using it as a dummy load and said to just move the end ring if I needed lower ohms of resistance(ie. that is to say less turns of the wire.)
