Wire to use for Traces
Discussion in 'General Electronics Chat' started by Seaker, Feb 5, 2013.
  1. Seaker
    Feb 3, 2013
    32
    I have a project that I am working on and will be using a single hole perf-board. The design calls for two long runs (DC+ and DC-). I intend to use the component leads where possible but need two extra stripped wires to facilitate the positive and negative runs. I hope you can follow what I am saying. The voltage on this circuit will be a maximum of 30 volts DC with 1.5 Amp of current.
    I know that there is coated .1mm trace wire but am concerned about its ability to handle current. The other option is stripping the insulation off of a couple 24 Gauge wires and using it.
    Thanks in advance.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    22AWG single strand wire will work.
  3. #12
    Nov 30, 2010
    16,663
    7,308
    24 is a bit small. Either run 2 wires per line or solder tack at every pad to use the board as a radiator.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    What will the length of these lines be?
    If < 12", 22ga would be fine. 24ga has a max rating of 2A in short runs, but it is generally good practice to stay far away from the max.
  5. Seaker
    Feb 3, 2013
    32
    Thank you all for the assistance!
