Wire Strain Relief
Discussion in 'General Electronics Chat' started by seecumulus, Aug 4, 2011.
  1. seecumulus
    Jul 13, 2011
    31
    Hello All -
    I would like some suggestions as to the best way to strain relief
    I/O wires on the edge of a circuit board.
    I/O wires qty. 19
    I/O wire guage ~ 18 guage
    These wires are soldered through hole method on the Card's Edge
    Connector.
    Suggest a bonding material / strain relief (ie.) Epoxy or other ?
    Thanks for any help
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    Hot glue.
    If room permits, create a small loop in each wire and glue the loop to the PCB.
  3. seecumulus
    Jul 13, 2011
    31
    Thank You.
    This poses a problem, there is no room.
    The wires are right on the card edge with very little card free area to bond to.
    Do manufacturer's use some foam flexible type glue or bonding material ?
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    Standing the wires straight up (perpendicular to the PCB) and placing some hot glue around the base of each wire will provide some strain relief. The hot glue maintains some flexibility even after it cools.
    In most applications, wires that are subject to continual flexing are specially designed for the purpose e.g., the ribbon cables in scanners and ink jet printers. In addition, they often have connectors to distribute the load across more surface area.
    I can't really imagine an application that would use 18 awg wires and that required continual flexing at the PCB. Care to say what the PCB is used in?
  5. seecumulus
    Jul 13, 2011
    31
    The Circuit Board is one of the First Generation Electric Vehicle
    Shunt DC Motor Controller Boards. We are talking a circuit board which is 25 + years old !
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    How about a (good) photo of the PCB and wire attachments? It may provide some ideas for options.
    Ken
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    Yes without a picture of the board showing the wire/attachment points and enclosure this thread is pointless.
