wire ORed
Discussion in 'Homework Help' started by swty_todd, Apr 2, 2009.
  1. swty_todd
    Thread Starter Active Member
    Aug 3, 2008
    82
    My textbook says that the output of comparators can be "wire ORed".
    What does wire OReding an output mean?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It has to do with open collector outputs. If you tie a bunch of collectors together sharing one resistor it is equivalent to an OR gate. It was a common practice in the days TTL logic was king.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To expand a bit on Bill's post, those open collector outputs are all pulled up with a single resistor. Thus any one output can pull the common line low.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. swty_todd
    Aug 3, 2008
    82
    sorry i forgot to mention that the above sentence was in respect to uA311 precision comparator.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It has an open collector output - the second paragraph of the intro on the data sheet stated that the device can be wire OR'ed. Open collector outputs are open collector outputs.
  7. leftyretro
    Nov 25, 2008
    394
    And of course wired OR can be accomplished by using series diode isolation between each of the 'voting' nodes and a single pull-up resistor so having open collector outputs is not the only way to be able to utilize wired OR stages.
    Lefty
