I am considering modifying an old push mower into an inductively guided robomower for my large back lawn (0.5 acre).
I currently have a commercial robotic mower in use in another lawn, its pretty good but has too small a blade for the big lawn and it mows in a random pattern which is sort of wasteful and is pretty ineffective on a big lawn.
My plan is to lay a wire just below the grass in a up down pattern and allow my bot to follow it verbatim.
The wire will emit a high frequency magnetic field which will be received by the robot and can follow it.
I have a few questions.
1) Since i want my mower to follow the wire. the wire will have to be very long (150m+), what will i have to consider when driving the signal in this regard do you think? (wire inductance could be high)
2) Any suggestions on generating the signal I might not have considered especially for such a long wire?
3) I plan on negotiating the wire by comparing the voltage entering the analogue pins of a microcontroller coming from an inductor/amp circuit. any overall tips would be super!
