Can anyone tell me how to wire this kit for battery use? (Please don't say read the PDF data sheet. Trust me, I have.) I would like to use 3 AAA batteries.
or rather from anode of D2 pad to Vout pad of the regulatorTake the regulator and the 1n4004 diode out and connect the + of the batteries to the place marked X2 then put a jumper wire from X2 to Vcc.
If you keep the diode, then you will reduce the available voltage by roughly 0.7v, and waste power. Is that really what you want to do?Well I wanted to keep the diode, but if it comes down to it, I'll remove it.
Yes. However, if you want to save on batteries, I suggest that you remove the regulator from the circuit entirely, as it will be a constant 5mA load even if it is not doing anything. This will only serve to generate heat and kill your batteries much faster than you'd like.In that case, Do I just jump the two outer pins of the regulator?
NO!Also, I didn't know the polarity of my LED, so I just removed it and jumped the gap. Is that okay?
by Aaron Carman
by Duane Benson
by Jake Hertz
by Jake Hertz
