I need a way to verify cables that were ran by a contractor. Due to the length and location of the run, I need it as simple as possible. Wires were mislabeled during the run and caused a headache during the setup.
Equipment:
1 x Klein Tools LAN Scout Junior VDV526-052
LAN Scout Manual
2 x CAT5 cables, Male Connector <------> Stripped Cable
2 x 8 Circuit Terminal Blocks
4 x Three-conductor shielded cable with metal foil shield and drain wire
Connection Setup:
LAN Scout Remote End - RJ45 - Terminal Block - Three-conductor Cable - Terminal Block - RJ45 - LAN Scout Remote
Identification:
Terminal Block
Circuit 1 - Cable 1, Black
2 - Cable 1, Clear
3 - Cable 2, Black
4 - Cable 2, Clear
5 - Cable 3, Black
6 - Cable 3, Clear
7 - Cable 4, Black
8 - Cable 4, Clear
I would like someone to verify or correct my wiring with the goal of rewiring the RJ45 side of the terminal block, allowing me to designate certain circuits to certain conductors
Equipment:
LAN Scout Manual
Connection Setup:
Identification:
Terminal Block
2 - Cable 1, Clear
3 - Cable 2, Black
4 - Cable 2, Clear
5 - Cable 3, Black
6 - Cable 3, Clear
7 - Cable 4, Black
8 - Cable 4, Clear
