Wire DC Power Jack for 9V Battery
Discussion in 'The Projects Forum' started by bubbagump0, May 27, 2010.
  1. bubbagump0
    Jul 10, 2007
    26
    I have a PCB which has a spot for a DC power jack, with three pins, but i'd like to use a 9V battery instead. Can anyone help me out on which pins are positive and negative?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    DC power can be wired with the center positive, but not always. You can use a LED with a 1000 ohm resistor in series to establish the jack polarity.
    The LED's short lead is the cathode.
  3. bubbagump0
    Jul 10, 2007
    26
    For some reason my images won't upload, but the 2.5 mm dc jack is center positive. I see that the center connection corresponds with the pin on the back of the jack, so I know where positive lead goes. Does that mean the other two pins should be negative? And would you recommend a different power source than 9V? The chip has an operating voltage of 2.4 to 5.5V. I'm using the 120 Second Voice Recorder Module found here:
    http://www.electronics123.com/s.nl;jsessionid=0a010a5c1f4397879837240b46ea9e10b67c688026c7.e3eSchuLcheTe34Pa38Ta38Lbhr0?it=A&id=2734&sc=8&category=2
  4. R!f@@
    Apr 2, 2009
    8,793
    771
    Center is positive the other two can be negative, but You might damage the circuit if you give 9V where it says 5.5V max
  5. whale
    Dec 21, 2008
    111
    hey guy,
    according to your module ,it can withstand up to 24v. 9v to 12v can be chosen for reliable operation.And to know your pin configuration , the pin in contact with the anode of the diode connected to your voltage regulator IC will be positive(+9v)( the diode near your DC source connector) and the center pin is ground (0v)and the other is negative(-9v).Thus it will resemble + 0 - or - 0 +
  6. R!f@@
    Apr 2, 2009
    8,793
    771
    Do you ever think twice before you say anything.
    Or am I the dummy.....:confused:
