Wire Clone
Discussion in 'General Electronics Chat' started by BluFox, Nov 27, 2015.
  1. BluFox
    Nov 23, 2015
    8
    image.jpeg Okay guys, so in out to ask what you all would probably suppose is the stupidest question ever asked here. The attached schematic is a project I am attempting. My question is, where it shows two wires going from the 12 volt psu to the led and the PIR. Does this mean I can splice a wire. Then make a fork in one wire to make it two wires?
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    Electricity doesn't care about the shape of the path for current to flow, just that there IS a path. The topology of a wire doesn't matter as long as 1) there is continuity from point to point and 2) the gauge of the wire does not restrict the current flow. So you can complete a circuit with a copper bar or a disk or a forked octopus. It doesn't matter. The current will follow the path.
    But do note #2 - you need a thick enough wire to carry the current for your load.
    BluFox likes this.
  3. BluFox
    Nov 23, 2015
    8
    Alrighty, thank you!
  4. spinnaker
    Oct 29, 2009
    5,115
    1,195
    The schematic is just drawn that way so it is easy to follow. If things were drawn the way they are wired then it would make a drawing hard to follow.
    And some people do try to draw them that way! :)
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    ..... particularly vehicle wiring draughtspeople!
  6. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Is that drafts people? You say draughtspeople in Wales?
    cmartinez likes this.
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Not this side of the pond.
    Well, in the Queen's English we say 'draughtsmen' and 'draughtswomen' ;).
  8. Dodgydave
    Jun 22, 2012
    5,171
    778
    We used to say that Alec, till the 'policial correct police' jumped in, now its "draughtsperson"
    Alec_t likes this.
  9. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Is it personhole cover then too? :) What we call those metal covers on the streets, access to utility lines and such.
  10. Dodgydave
    Jun 22, 2012
    5,171
    778
    No, its called an "inspection cover, or chamber" i know its daft... wtf#! o_O
  11. Alec_t
    Sep 17, 2013
    5,980
    1,138
    I'm not aware we've got that far. And I doubt 'womanhole cover' would be acceptable, for obvious reasons :).
    boatsman and Dodgydave like this.
  12. boatsman
    Jan 17, 2008
    165
    394
    I suppose manual labour is not politically correct nowadays.
  13. Dodgydave
    Jun 22, 2012
    5,171
    778
    Thought he was a Spaniard.. Lol:p
  14. be80be
    Jul 5, 2008
    432
    57
    You know cap's can can become a problem on point to point wiring where the cap looks like it's after the IC I've seen this happen more than one time on strip board. I've had to move caps legs closer to the IC and the other closer to the power I guess it's the resistance. But good planning works.
