windows vista home premium
Discussion in 'Computing and Networks' started by hartlanders, Oct 8, 2007.
  1. hartlanders
    Mar 20, 2005
    :confused:The computer is an hp s7700e.the processor is a amd athlon
    dual core,1 gig memory,160 gig hd .i have avg free edition,adware,
    and windows defender.i run adware and and virus scanner once a week.
    it never shows a problem.i also have ccleaner installed that i run when
    i disconnect.
    The problem is computer is very slow when i go to any website,it takes along time for page to load.When i purchased computer i used all recomended hardware.is this common with vista?
    Thanks for any replies,hartlanders
  2. recca02
    Apr 2, 2007
    1,211
    the website loading speed depends on your internet connection speed and the load on the server,
    so it probably does not have much to do with your pc configuration,
    maybe the antivirus and other softwares are running updates which might have slowed the websites' loading.
    the other thing about pc being slow beats me too,
    i have seen some pc do not perform to their specifications,
    maybe u are running too many applications at start up in the background.
  3. Firestorm
    Jan 24, 2005
    353
    You can test your internet speed @ http://speedtest.net
    The one thing I don't like about vista is that it uses too many resources just for a few "fancy" effects. I turned most of that stuff off(If you would like, I can send you a pic of my visualization setup...ie-whats on and off). AVG doesn't take up that much stuff, so it could be dependent on you internet connection. Try using a different spyware remover(SpyBot S&D) and see if that speeds it up. Hope this helps :)
    -fire
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    2 gig of memory is a real help if you're using Vista. You might consider falling back to XP.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If you net connection speed is good and you are still experiencing problems, I might assume that your problem is your AV over working and thus slowing your connection. Although I don't recommend it for general use, what happens if you disable you AV as then use the net? (only navigate to a trusted site and turn your AV back on ASAP).
    If the net experinece is more responsive may I suggest you then look at replacing AVG with another software (Avast! is good and free). Btw, I find AVG is very good and highly recommend it, however sometimes the best software doesn't suit your set-up.
    Dave
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    Vista uses lots of resources, making a normal computer to act slow. Most of them are used on data encryption (when active), DRM processes and such. I really suggest you to uninstall it. Vista needs a lot of memory: 512Mb at least, and demands a lot from the processor.
    But then again, is your computer really slow, or only takes time to load a page?
  7. hartlanders
    Mar 20, 2005
    The computer takes a long time to load
    pages no matter what sites i go to.
    I have had the computer for 8 months
    when i go to defragment it always says
    files system performance is good,you do
    not need to defragment at this time.Can
    this be possible after 8 months of use?
    Thanks,hartlanders:confused:
    ps what is DRM processes how do you
    disable it?
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    As long as you have not changed any of the default settings, defragmenattion should happen automatically. Therefore the information is correct. You can check your actual file fragmentation at the command line by typing:
    Code ( (Unknown Language)):
    1. defrag c: -a
    Note: The command line process must have administrator rights.
    There is not a lot you can do, its built into the core of the OS.
    Dave
