windows help
Discussion in 'Computing and Networks' started by sharma2k7, Jan 24, 2008.
  1. sharma2k7
    Thread Starter Active Member
    Dec 10, 2007
    36
    every time i double clicked any of my drives in my computer window it will not open up in the same window it will open in new window what can i do for this somebody please help me !
    i already format my c drive and re installed my OS windows xp professional sp 2
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Open any folder. Look at the tool bar, and click "TOOLS". Click "FOLDER OPTIONS". Under the General tab, look at the BROWSE FOLDERS choices. Click the "OPEN EACH FOLDER IN ITS OWN WINDOW" choice. All there is to it.
  3. sharma2k7
    Dec 10, 2007
    36
    ya i did it but there is no change it happens only from this morning
  4. recca02
    Apr 2, 2007
    1,211
    again its the same type of virus like B4.
    do a virus scan.
    after that turn show hidden folders and show system files options ON.
    (if u cant do this like b4 run that file...after extracting it..the same file..posted in previous discussion).
    right after that open each dirve and delete the autorun and the file mentioned in the autorun.
    reboot...
    this is again one of those removable drives virus..that infects ur pc as soon as u double click it...
    use this file(http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx) to remove the autoplay option.this shud prevent such virus from affecting ur pc.
  5. sharma2k7
    Dec 10, 2007
    36
    Thanks Mr Recca i can't found any files named autorun in any drive even in hidden files but i saw AUTOEXEC.BAT file through command window and delete it .Now i have no such file still i m in same problem
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Should you have done that? See: http://en.wikipedia.org/wiki/AUTOEXEC.BAT
    Dave
  7. recca02
    Apr 2, 2007
    1,211
    yeah autoexec.bat shud not be erased....
    can u tell me the rightclick options for the drives.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The AUTOEXEC.BAT file needs to be present, but may be blank in an XP system. It may be ok just to make a folder in the root directory named AUTOEXEC.BAT.
  9. sharma2k7
    Dec 10, 2007
    36
    thanks Mr Dave now i am not found any autorun file but still i have the problem
    each drive opens in new window
  10. sharma2k7
    Dec 10, 2007
    36
    In right click also i have the same problem it is also opens in new window
  11. recca02
    Apr 2, 2007
    1,211
    i meant if u right click on a drive, what are the first 3-4 options?
    again just fir the sake of confirmation...can u see hidden and system files using folder option.
    and did u make a virus scan using a antivirus..like avast?
    i have seen countless problems like yours and everytime(unless the problem wasnt due to a change...like MR Beenthere suggested.) it was due to an autorun.ini and the file which this files asks to open ,both of which were generated by a virus.
  12. sharma2k7
    Dec 10, 2007
    36
    the first four options when i right click are open, explore , search .sharing and security...............
  13. recca02
    Apr 2, 2007
    1,211
    this does not seem the problem which i thought it wud be.
    had it been that, one of the option wud have been something fishy...like two open options, or one autoplay option.
    in that case this seems to be some change in setting...
    one last attempt..what are the hidden files that u can see in a drive after opening it?
  14. sharma2k7
    Dec 10, 2007
    36
    Mr .Recca now i can't get hidden files through folder options i can get onle through advanced search options
    but i m not getting anything new in hidden files other i manually hidden
  15. recca02
    Apr 2, 2007
    1,211
    it seems that this is indeed a virus infection..
    i once again recommend a virus scan....make sure u have virus definitions updated.
    if possible make a boot time scan
    after which either use this or the previous file i attached to fix the folder option.
    try to extract the file and then use...
    then i think u shud be able to see hidden files when u open a drive.
    then if u see auotrun.ini file delete it.
    • RRT.zip
      File size:
      15.9 KB
      11
  16. sharma2k7
    Dec 10, 2007
    36
    Thanks Mr.Recca i did boot time scan with avast.During boot time scan i knew that 50 of .dll and .exe files in D/system volume information /.........etc were affected by win 32 :trojen-gen and adware when tried to delete it during the boot scan i can't it gives error :the file in not packed
    i can't delete any of the affected file .help me what can i do further
    i extracted the above link u given and i use it but nothing has changed..
