windows comparator
Discussion in 'The Projects Forum' started by sharpice, Jul 4, 2013.
  1. sharpice
    Jul 4, 2013
    im having this problem with my windows comparator circuit which is feeding a 555 timer. my 555 timer is activated even there is no inputs to the opamp (741) except the power supplies which are connected at both polarities. how do i remove this voltage output from the opamp
  2. sheldons
    Oct 26, 2011
    616
    101
    post schematic- my crystal ball is being polished and serviced at the moment
  3. sharpice
    Jul 4, 2013
    unable to insert image. it says insert url. how do i get around that?
  4. LDC3
    Apr 27, 2013
    920
    160
    Under the "Quick Reply Message Box" is a button that says "Go Advanced" - click there. Above the "Message Box" is a paper clip - click there and in the pop-up windows, browse to the file to upload, click upload and then close the window. When you post your message, the file is attached.
    sharpice likes this.
  5. sharpice
    Jul 4, 2013
    image attached.thanks
  6. LDC3
    Apr 27, 2013
    920
    160
    First, I would connect pins 4 & 8 to the battery supply so the 555 is always powered. And add a capacitor from pin 5 to ground. Your circuit will power the 555 as long as the 741 has a high output. The moment the 741 output goes low, the 555 runs out of power quickly.
    Now the question is, do you want the 555 to trigger
    1) immediately when the 741 go high or
    2) after a delay defined by the RC network?
  7. LDC3
    Apr 27, 2013
    920
    160
    If I read the resistance correctly, you have a 1K resistor and a 1K potentiometer with a 100μF capacitor. If this is correct, the frequency is about 4.8Hz with a 66% duty cycle.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    That doesn't make sense to me. Now you are the one who needs to post a schematic.:D
  9. LDC3
    Apr 27, 2013
    920
    160
    It will have to wait until I get home in about 5 hours.
  10. wayneh
    Sep 9, 2010
    12,368
    3,224
    Where does the 555 get power when the op-amp goes low? Maybe you were referring to something else not making sense.
  11. tubeguy
    Nov 3, 2012
    1,157
    197
    Why not connect 555 pin 8 to V+, add the cap to pin 5, but connect 555 pin 4 to the 741 output for on/off control of the 555 ?
    Happy 4th everybody :)
  12. Ron H
    Apr 14, 2005
    7,050
    657
    LCD said
    If the 555 is connected directly to the battery, how does the 741 affect anything?
  13. LDC3
    Apr 27, 2013
    920
    160
    In the OP's schematic, the output of the 741 is connected to the end of the RC circuit. In this case the 555 doesn't run unless the output of the 741 is high.
    In many instances, it is connected to pin 2 of the 555. In this case, the 555 provides 1 pulse on pin 3.
  14. Ron H
    Apr 14, 2005
    7,050
    657
    OK, I get it.:(
    I must have been half asleep when I looked at the schematic.
  15. LDC3
    Apr 27, 2013
    920
    160
    Here it is. I have only made the changes in the first paragraph of the message.
    Now, how do you want the 555 to respond to the signal from the 741?
  16. Ron H
    Apr 14, 2005
    7,050
    657
    The timing calculation equations won't be accurate, because the 741 output won't go to the positive rail.
  17. LDC3
    Apr 27, 2013
    920
    160
    True, but we still don't know how the OP wants to connect them together. Maybe he just wants a single buzz and flash instead of a series of buzzes and flashes.
  18. Ron H
    Apr 14, 2005
    7,050
    657
    Agreed. I was just throwing out a caveat.
