Windows audio loopback?
Discussion in 'Computing and Networks' started by Distort10n, Aug 12, 2008.
  1. Distort10n
    Thread Starter Active Member
    Dec 25, 2006
    429
    Does anyone know if it is possible to use a microphone plugged into a laptop mic-jack and listen to one's own voice in real time besides having to record it first?
    I need to run some audio tests on a laptop thru an Audio Precision. I know I can record a file then play it back, but I will have to run the AP in open-loop and set the external trigger. A bit of a pain.
    If it is possible to use the AP as the generator itself through the mic-jack and loop it back through the headphone jack in real time, then I can set up the AP analyzer to track its own generator output (easier!).
    Can Windows do this 'audio loopback' jazz?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Not that I'm aware. I think you have to record first, either through the Sound Recorder utility or through a 3rd party app like Audacity.
    Dave
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There are loopback programs available, but the loop goes the wrong way. They use the DAC to generate waveforms to play through the ADC to check frequency response.
  4. mik3
    Feb 4, 2008
    4,846
    63
    If you have a software which records and another which plays the music you can do it but dont turn on the volume to much because you may destroy the sound card. The signal form a microphone is not very strong but the signal from the output of the laptop for the headphones is stronger to drive them so be careful not to destroy the sound card.
