Windo comparator using LM311 to compare between 3.3v to -24vdc
Discussion in 'General Electronics Chat' started by Sigamani, Feb 13, 2014.
  1. Sigamani
    Apr 6, 2012
    5
    Dear Sirs,
    Using NI Multisim version 13.0, windo comparators works fine when comparing voltages between 9 to 24Vdc.
    However it fails when comparing 3.3 to -24vdc.
    Will the comparator, LM311 able to compare the 3.3 to -24vdc?
    Any help in this would be very much appreciated.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Only if you give it the right power supply voltages.
    Sigamani likes this.
  3. crutschow
    Mar 14, 2008
    13,526
    3,393
    The LM311 can't compare voltages below it's negative supply voltage.
    Post your circuit diagram.
  4. Sigamani
    Apr 6, 2012
    5
    Hi Thanks for the help.
    1. I have given the right voltage supply (in MultiSim) still no luck.
    2. Supply voltage is +/- 18 volts. The upper and lower limys are 3.3v and -24volts. Sensing voltage is -10v.
    I will post the drawing tonight (Sorry at work now)
  5. Sigamani
    Apr 6, 2012
    5
    Hi I have attached the drawing.
    please help.
    Mani
  6. tindel
    Sep 16, 2012
    576
    196
    It looks like your supply is negative and you've given it a '-18V'... that's a double negative, making a positive. Change the polarity of your negative voltage or remove the '-' from the voltage level... not both. Then your sim should work.
  7. Sigamani
    Apr 6, 2012
    5
    Hi tindel et al, thanks for the help.
    I have sorted supply voltages and the simulation is working fine now.
  8. crutschow
    Mar 14, 2008
    13,526
    3,393
    Note that ±18V is the absolute maximum supply voltage allowed for the LM311. You should keep it no greater than ±15V for reliability. Also the worst-case input voltage range is 13V to -14.5V. If you need to detect input voltages higher then that, you can use resistive voltage dividers (bridge circuit) on the inputs.
  9. Sigamani
    Apr 6, 2012
    5
    Hi crustchow, many thanks for the info. It was a great help.
    very much appreciated. Thanks.
