Greetings again,
This time I am wanting to put a wind sensor on my solar panel array. The idea is that if the wind picks up then I will rotate panels to the horizontal position to limit stress. The solar panel array is about 10' x 10, and it's at the top of a 6"x10" I-beam 15' in the air. It can get up to 5000 lbs of force with a good storm, hence the desire to go horizontal.
So back to wind sensors. I'd like something that is reliable. It seems every rotating wind sensor I see is both a bit expensive ($30+ each, and if I put 1 per tower then I'll need a dozen!). One sensor I've seen that looks interesting is this one:
http://shop.moderndevice.com/products/wind-sensor
It's called a 'hot wire'. Basically you run power through a wire and wind cools it. Measure temperature and you can translate that into wind speed. Interesting approach.
My question is if anyone has used this method? How reliable is this design? Damage from leaves in the wind/etc? Unreliable in rain?
Tony
Tony
