I have a treadmill motor I am working on using as a 12V battery charger. I basically have two questions regarding some of the controlling of the prop speed.
The motor specs are:
Electrical Rating @ 130VDC
2.50 HP
18 AMPS
6700 RPM
1) Do I assume that as long as the RPM rating is not exceeded that I would not
overheat or damage the motor?
2) In the case that I need or want a braking system, what might be the method
I could use. My friend said that using a rpm detection circuit to trigger a resistor short across the motor would be a good braking system?
Any thoughts?
2.50 HP
18 AMPS
6700 RPM
Any thoughts?
