Willing to pay for help
Discussion in 'Programmer's Corner' started by Foxhunter, Nov 24, 2009.
  1. Foxhunter
    Nov 3, 2009
    Hi I am willing to pay for help
    what I need to know is how to make the leds in the following programe file fade using PWM
    and is it possable to hold all the ports used in the on state with the touch of a button
    you can email me at <snip>
    yours john
    Moderator's note: we insist that answers be given in the forums so as many as possible get the benefit.
    ;* VELLEMAN High-Q KIT K8048/VM111 SAMPLE SOFTWARE *
    ;* DEMO1: Simple Running light for testing LD1...LD5 *
    ;* DEMO1: Program for testing K8048/VM111 with PIC16F628a *
    ;* (C) VELLEMAN Components,2003 All rights reserved *
    ;* Hardw. Rev: P8048'1 Softw. Rev: 1.20 *
    ;* OSC.......: XT 4MHz Max. POWER.....: 12V DC *
    W EQU H'0000'
    F EQU H'0001'
    ;----- Register Files------------------------------------------------------
    INDF EQU H'0000'
    TMR0 EQU H'0001'
    PCL EQU H'0002'
    STATUS EQU H'0003'
    FSR EQU H'0004'
    PORTA EQU H'0005'
    PORTB EQU H'0006'
    INTCON EQU H'000B'
    OPTION_REG EQU H'0081'
    TRISA EQU H'0085'
    TRISB EQU H'0086'
    CMCON EQU H'001F'
    ;----- STATUS Bits --------------------------------------------------------
    IRP EQU H'0007'
    RP1 EQU H'0006'
    RP0 EQU H'0005'
    NOT_TO EQU H'0004'
    NOT_PD EQU H'0003'
    Z EQU H'0002'
    DC EQU H'0001'
    C EQU H'0000'
    ; RAM Definition
    __MAXRAM H'01FF'
    __BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
    __BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
    __BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
    __BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
    ; Configuration Bits
    _BODEN_ON EQU H'3FFF'
    _BODEN_OFF EQU H'3FBF'
    _CP_ALL EQU H'03FF'
    _CP_75 EQU H'17FF'
    _CP_50 EQU H'2BFF'
    _CP_OFF EQU H'3FFF'
    _DATA_CP_ON EQU H'3EFF'
    _DATA_CP_OFF EQU H'3FFF'
    _PWRTE_OFF EQU H'3FFF'
    _PWRTE_ON EQU H'3FF7'
    _WDT_ON EQU H'3FFF'
    _WDT_OFF EQU H'3FFB'
    _LVP_ON EQU H'3FFF'
    _LVP_OFF EQU H'3F7F'
    _MCLRE_ON EQU H'3FFF'
    _MCLRE_OFF EQU H'3FDF'
    _ER_OSC_CLKOUT EQU H'3FFF'
    _ER_OSC_NOCLKOUT EQU H'3FFE'
    _INTRC_OSC_CLKOUT EQU H'3FFD'
    _INTRC_OSC_NOCLKOUT EQU H'3FFC'
    _EXTCLK_OSC EQU H'3FEF'
    _LP_OSC EQU H'3FEC'
    _XT_OSC EQU H'3FED'
    _HS_OSC EQU H'3FEE'
    __CONFIG _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
    ; Variable Definition
    TIMER1 EQU H'20' ;Used in delay routine
    TIMER2 EQU H'21' ; " " "
    PATERN EQU H'22' ;Pattern data for effect's
    ORG 0 ;Reset vector address
    GOTO RESET ;goto RESET routine when boot.
    ; * Example of a delay routine *
    DELAY_ROUTINE MOVLW D'255' ;54 Generate approx 10mS delay at 4Mhz CLK
    MOVWF TIMER2
    DEL_LOOP1 MOVLW D'255' ;60
    MOVWF TIMER1
    DEL_LOOP2 DECFSZ TIMER1,F
    GOTO DEL_LOOP2
    DECFSZ TIMER2,F
    GOTO DEL_LOOP1
    RETLW 0
    ; ** RESET : main boot routine **
    RESET MOVLW B'00000111' ;Disable Comparator module's
    MOVWF CMCON
    BSF STATUS,RP0 ;Switch to register bank 1
    ;Disable pull-ups
    ;INT on rising edge
    ;TMR0 to CLKOUT
    ;TMR0 Incr low2high trans.
    ;Prescaler assign to Timer0
    ;Prescaler rate is 1:256
    MOVLW B'11010111' ;Set PIC options (See datasheet).
    MOVWF OPTION_REG ;Write the OPTION register.
    CLRF INTCON ;Disable interrupts
    MOVLW B'11000000'
    MOVWF TRISB ;RB7 & RB6 are inputs.
    ;RB5...RB0 are outputs.
    MOVLW B'11111111' ;all RA ports are inputs
    MOVWF TRISA
    BCF STATUS,RP0 ;Switch Back to reg. Bank 0
    CLRF PORTB
    EFFECT_1 MOVLW B'00000001' ;Activate LD1 (RB0)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00000010' ;Activate LD2 (RB1)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00000100' ;Activate LD3 (RB2)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00001000' ;Activate LD4 (RB3)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00010000' ;Activate LD5 (RB4)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    MOVLW B'00100000' ;Activate LD6 (RB5)
    MOVWF PORTB
    CALL DELAY_ROUTINE
    GOTO EFFECT_1
    END
