Will this work..?
Discussion in 'General Electronics Chat' started by R!f@@, Jan 30, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,789
    771
    I was wondering about the way the LM311 is wired ..
    can any one check it and tell that whether it is right or wrong ? :confused:
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Looks indeed very strange. The ground pin is at the output, the output together with the power supply pin, stabilized via a zener diode?
    Maybe it's an other chip? Where is it from?
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I see no problems with the schematic.
    When you look at the internal schematic of the 311, you see that 7 is the collector of the output transistor and 1 is the (current limited) emittor output.
    Bertus
  4. R!f@@
    Apr 2, 2009
    8,789
    771
    Well , I'll be a monkey's Uncle..
    Should have gone thru that .!!!
    Thanks Bert....
