Will this system need a fuse?
Discussion in 'The Projects Forum' started by Metallica1992, Dec 30, 2009.
  1. Metallica1992
    Dec 27, 2009
    Basically i need to know if this contraption i have made up will need anything else to work and not malfunction...
    i got this
    [​IMG][​IMG]
    To one of these...
    http://www.oznium.com/cathode-music
    Which is hooked up to two of these...
    The strips are about six inches in length, I believe.
    http://www.oznium.com/led-flex-strips
    I am not sure if i need anything else, like perhaps a fuse. I tested this whole thing out and it does work but the test was only for a short period of time and I am not sure if for long-term usage, if I should have a fuse or resistor of some sort on here. (I am a novice with wiring)
    Thanks for any and all help.
  2. fkuk
    Dec 17, 2009
    7
    i dont think batterys are going to last very long in this set up
    i would rather get a 12volt adapter charger 1amp or so
    6 inch of leds is 100mA
    so 12 inches is 200mA
    the sound box doesnt say what current it draws
    in my opinion if you use a suitable wire size and you wire it correctly you dont need a fuse
  3. Metallica1992
    Dec 27, 2009
    ok thank you, yeah I tried the adapter but the fuse kept blowing on it for some reason and now i the radioshacks i go to dont have the specific fuses in stock, so I am just going to stick with batteries for now, even if they dont last too long.
  4. Ante
    Dec 25, 2009
    10
    Wouldn’t hurt to fit a fuse, especially if the high consumption of power eventually requires the use of rechargeables. These can in case of a short produce very high currents and catch fire.
  5. fkuk
    Dec 17, 2009
    7
    how are you fitting the fuse?
  6. Ante
    Dec 25, 2009
    10
    On the wire between the two cellpacks would be one suitable place for a fuse.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    A fuse can never hurt, but this uses AA batteries. I don't think I would bother myself.
    If you have a wall wart maybe, but most cases a non replaceable fuse is included inside the wall wart itself.
