I found the attachment in TI's LM150 datasheet. If the resistor won't burn up, would someone be kind enough to explain why not?
Why would you expect it to burn up if your load needs less than 2 watts?I found the attachment in TI's LM150 datasheet. If the resistor won't burn up, would someone be kind enough to explain why not?
maybe, but that's because most of the data sheets had to go across my desk for final check before they got published.Don't whine too much. They are right a lot more than they are wrong, like 999 to 1.
by Don Wilcher
by Duane Benson
by Aaron Carman
