Will this relay work for 120VAC
Discussion in 'General Electronics Chat' started by vindicate, Jul 5, 2010.
  1. vindicate
    Thread Starter Active Member
    Jul 9, 2009
    158
  2. Dx3
    Member
    Jun 19, 2010
    87
    7
    The label says it will survive switching voltage as high as 250 VAC. That includes 120 VAC.
  3. KMoffett
    Dec 19, 2007
    2,586
    234
  4. BMorse
    Sep 26, 2009
    2,675
    234
  5. vindicate
    Jul 9, 2009
    158
    Switch 120VAC :)
    So if I want this to switch say, a fan, that would be in the 2A section correct?
  6. KMoffett
    Dec 19, 2007
    2,586
    234
    Yes.
    Ken
  7. vindicate
    Jul 9, 2009
    158
    Out of curiosity what happens if you give the coil more than 6V?
  8. BMorse
    Sep 26, 2009
    2,675
    234
    Depending on how much more, it could quickly heat up and short out the coil, then you will have to replace it.... worst case (9volts), you will get a lot of chatter from it, then, have to replace it...
    B. Morse
  9. KMoffett
    Dec 19, 2007
    2,586
    234
    It will cause the coil to heat up. The higher the over-voltage the more the heat, until it burns out and/or melts the plastic parts.
    Ken
  10. KMoffett
    Dec 19, 2007
    2,586
    234
    Out of curiosity why would 9vdc on the coil cause a 6vdc relay to chatter?
    Ken
  11. retched
    Dec 5, 2009
    5,201
    313
    I'm guessing he is speaking from experience ;)
