I am working on a 12v project using the P7 LED (2800mA). I found this driver that is made for this specific LED but it says the Max Input is 35v. It doesn't give a Min Input. Does anyone know if this will run one P7 LED off of a 12vdc battery?
KONLUX2800 High Power constant current source 2800 mA for operating Seoul P7 ® LEDs and similar components
High efficiency and low heat by modern switching technology. The use of special amplifiers guarantees a precise and constant output-current. Small dimensions, low weight and high reliability through the use of SMD-technology (surface mounted components). Every HKO is electronically tested..
Technical data KONLUX2800:
Startup: ca. 5,1 volts (for one P7) with reverse polartiy protection
Startup: ca. 4,7 volts (for one P7) without reverse polarity protection
Drop: ca. 2 volts
Maximum input voltage: 35 V DC
Output: Short circuit protected
Output current: 2800 mA constant
Input: reverse polarity protected (can be passed)
Tolerance < 3% over the complete voltage range
Efficiency: depending on the count of LEDs and input voltage between 75 und 90 %
Thermal protection
Working temperature range: -40 °C to +85 °C
To drive up to 9 P7 Leds in series with 35 volts input for maximum light power! The LEDs must be cooled, please refer to the data sheets of the manufacturer. The back side of the CCS is covered wth tinned copper, it is connected to minus input (don´t forget, when mounting the constant current source). The KONLUX 2800 must be cooled for continous operation . The printed circuit board can be easily mounted on a heat sink or metal surface with the self adhesive cooltape. Due to the high currents in the input of the circuit additional filtering may be necessary. Please check. We recommend very short cables to the power source.
Printed circuit board:
Dimensions: 30 mm x 31 mm, 7 mm high
Connections: soldering pads
Weight: approx. 5 grams
Material: FR4
Back side: copper, tinned, connected with - IN
http://www.dotlight.de/products/en/...constant-current-source-KONLUX-DC-2800mA.html
Thank you all who have helped with my previous questions.
Drop: ca. 2 volts
Thermal protection
Material: FR4
