Will This Circuit Work?
Discussion in 'The Projects Forum' started by Chris15, Nov 10, 2010.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    http://electroschematics.com/6161/power-switch-with-infrared-proximity-sensor/
    I have an LM567, and i want to make this, simply, will it work, does it look like it will work is their anything i can change to make it better.
    Also that thing S20, what is that? a IR LED with a phototransistor?
    Can i just use an IR LED and a Phototransistor instead of that thing, becuase my electronics store dont have it. What is it called?
    - Optoisolater?
    Thanks, Chris
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The circuit will probabbly work well.
    The NE567 is a PLL locked tone detector.
    The S20 is a solid state relays.
    There are several types of them, depending on the switched load.
    Bertus
  3. Chris15
    Apr 15, 2009
    252
    Ohk thanks bertus
    so, solid state relay sorry what does that mean
    i remember briefly learning about them, but i dont understand them
  4. Chris15
    Apr 15, 2009
    252
    And how does that thing S20 work?
    do i need to get that s20 thing, cant i make it another way
    like, have an IR LED, then a phototransistor, and make it power a relay that i can make latch, or if i can get solid state relay do they all have that LED thing with diodes?
  5. Chris15
    Apr 15, 2009
    252
    Also, would a way to increase the proximity distance to maybe a meter, or a doorway just put the led in a lense
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    Don't forget, your light source will need to be pulsed. That is the whole purpose of using the LM567. From its datasheet, you can find what the pulse frequency will need to be and change
    (f = 1/(1.1*R_{timing}*C_{timing}) the iming components accordingly.
    As drawn, and using R5 and C2 that frequency is about
    2KHz.
    John
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here is a PDF on solid state relays.
    I hope this will give you some better insight on them.
    Bertus
    Chris15 likes this.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    I think it is worthwhile to find out what your reception distance is with this circuit, since you have most of the components already. You can test the effective distance without the solid state relay (SSR).
    If you want greater distance, I suggest an IR receiver and transmitter pair, such as the Vishay TSOP series of devices. To achieve that greater distance the transmitter protocol is more complicated, and there is greater noise/false signal rejection.
    This device with the SSR has potential to control some fairly powerful equipment. Be sure to have enough safety devices in the system so that an unintentional start or stop doesn't do any harm.
    John
    Chris15 likes this.
