will this circuit work
Discussion in 'The Projects Forum' started by swty_todd, Dec 27, 2009.
  1. swty_todd
    Thread Starter Active Member
    Aug 3, 2008
    82
    [​IMG][​IMG]
    We have to make a miniproject as part of my engineering course. I chose the above intruder alarm (got the circuit from the net).
    I thought that there were some mistakes and I have made some changes (therefore some things are written in black).
    I did be grateful if you guys could confirm whether the circuit will work theoretically and practically.
    Let me know if I have made some mistakes.
    Here IC2 uA 741 is wired as a sensitive comparator ,whose set point is set by R6 & R7.
    The voltage divide by LDR and R8 is given at non inverting pin of IC2.
    At standby mode R8 is made little more than LDR so that the output of pin 6 will be low
    Transistor Q1 will be off.
    The voltage at trigger pin of IC1 will be positive and there will be no alarm.
    When there is an intruder near the LDR the shadow causes its resistance to increase.
    The output of IC2 will be high once LDR becomes more than R8
    This makes Q1 on.
    This makes a negative going pulse to trigger the IC1 which is wired as a monostable multivibrator.
    The output of IC1 will be amplified by Q2 (SL 100) to produce alarm.
    I have one more question should I use SL 100 as Q1?
    Thanks,
  2. mik3
    Feb 4, 2008
    4,846
    63
    Why do you need the 555?
    Do you want the buzzer to turn off after some time?
  3. swty_todd
    Aug 3, 2008
    82
    I have used 555 for the following reasons:
    1.It was there originally(I took the circuit off the internet)
    2.I have worked with 555 before.
    3.I can't think of an alternative to 555. Can you suggest an alternative?
    Between thinking of your question , I am confused a little. I think the position of my buzzer is wrong. I think one end should be connected to the transistor and the other end should be connected to ground. And what is the difference between speaker and buzzers , they seem to be shown by the same symbols in circuits.
  4. DickCappels
    Aug 21, 2008
    2,777
    674
    I don't know if there is a common schematic symbol for a buzzer. You can connect it as shown, but check the "buzzer's" data sheet and determine if it needs a capacitor across its power supply connections.
    And of course "buzzer" makes me think of one of those electromagnetic buzzers, and if you use one, then put a diode across the coil with the anode on the transistor's collector and the cathode on the positive power supply.
    Have you thought about what you are going to use as a buzzer? The way you have it set up, it will get 9 volts across it when it goes off.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Looks like the 555 is just a 10 second monostable. So if the beam is briefly broken, the buzzer will stay on for 10 seconds, not just chirp briefly. The wiring for the 555 output, the transistor and the buzzer appear correct.
    Ken
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    I think you would be better off with one of those radio shack piezo oscillators. They will pull much less current and they can be quite loud. No protection diode needed either. ;)
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    The 741 will not work, or if it does it is iffy. The power supply is way low, 741 requires +/- 15VDC typically. Use a LM3909 quad comparitor (don't forget the pull up resistor). If you must use a conventional op amp think LM324 quad op amp.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bill,
    I think you meant an LM339 quad comparator.
  9. CDRIVE
    Jul 1, 2008
    2,223
    99
    Here's an equivalent circuit (functionally) using a Picaxe microcontroller. Yeah, I know... You must be asking...where did all the components go? :confused::eek:
      File size:
      56.6 KB
      56
  10. zhgart
    Dec 28, 2009
    19
    you can cancel the q1,and q2, but you hve to change 741 situation reverse. 741 can be comparator as 393 or 339. no problem. if buzzer has driver inside, you can save 555 but have to us q2.
  11. JoeJester
    Apr 26, 2005
    3,402
    1,227
    The LDR/R8 junction needs to be tied to the inverting input. The reference becomes the non-inverting input.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep, tired computing again.
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    An LM339 has 4 low power comparators and has a 14 pins case.
    An LM393 has 2 low power comparators the same as in the LM339 and has an 8 pins case.
    You can buy an SL100 transistor in India.
