I didn't know how to properly draw the 555 timer, so I used a switch for pin 3 (Out)
I finally figured out this circuit with two LED's, a 555 timer, two 300ohm resistors, and one NPN transistor. When (Out) is high the bottom LED will turn on, and when it's low the top LED will turn on.
I tried looking up how much current the 555 timers can take and found it was only about 100ma. I want to run 20 leds, 10 on and 10 off depending on the output of the 555 timer.
10 x 20ma = 200 ma, so I added the TIP41c NPN to hopefully help, but the TOP LED worries me because it attaches back to the 555 Timer for ground. (I think) Won't that send too much current to the 555 timer?
No other variation I've tried with one NPN transistor would create a toggle flash between the LED's. Would I need a second transistor to save the 555 timer?
Thanks !
