I have an application that requires a relay. I am using an input signal to the coil that once was used to control a fluorescent light so it has a high frequency, around 55Khz (also has a peak voltage of around 240). I have tried using a 120VAC relay with a resistor in series with the relay coil to step the voltage down, but it is not working because of the frequency I think (since I measured the voltage at the relay coil input on the scope as 175, and 118V with a DVM seems like this should be right). So I want to know if this might work instead...Use a full wave rectifier circuit to create a DC signal then use a series resistor with the relay coil to make a voltage divider to step the voltage down to around 24VDC, and then use a relay with a 24VDC coil input. Will this work?? Anyone have any other ideas or better ways to accomplish this? Thanks.
