Will there be any voltage????
Discussion in 'General Electronics Chat' started by nirmal_rockin, Sep 17, 2009.
  1. nirmal_rockin
    Aug 7, 2009
    19
    Do i get any voltage in the crystal oscillator connected externally to the atmega16l...when the mc is switched on....
  2. mik3
    Feb 4, 2008
    4,846
    63
    Yes, if you connect an oscilloscope across the crystal you will see a varying voltage at the frequency of the crystal.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you tried measuring it with a multimeter, you probably won't read anything, as the meter would load the circuit down too much. Even an O-scope probe can cause too much loading, preventing it from oscillating. In such cases, you can frequently get a waveform by simply holding the 'scope probe very close to the circuit, but not actually touch it.
