Will the voltage be same here?
Discussion in 'Homework Help' started by engg_fahd, Jan 12, 2012.
  1. engg_fahd
    Feb 23, 2011
    8
    Hello. In the circuit below the 20V source and 14 ohm resistor are in parellel with each other. Will the voltage across 14 ohm resistor be 20V ? I am getting confused because of the resistor in between the two parallel connections. :confused:
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    How's this ?
      File size:
      21.9 KB
      35
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    A) Cheating
    B) You forgot the current source on the right, so incorrect also. :p
    To the OP: Are you supposed to use node or mesh analysis to solve this?
    The voltage at the two points mentioned won't be the same, since there is a resistor between those two points.
    The only time two points are at the same potential is when they are connected with only a wire.
  4. R!f@@
    Apr 2, 2009
    8,793
    771
    I figured it to be an ammeter. Was in a hurry though.
    Now when u said it it was a current source.
    Thanks for pointing it out. hope OP wasn't disappointing.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    As it is the only unknown, it is fine.
    We just need the OP to understand the equations to get those numbers.
  6. engg_fahd
    Feb 23, 2011
    8
    Thanks to both of you for clearing the concept :)
  7. jegues
    Sep 13, 2010
    735
    43
    As thatoneguy has already mentioned, the 20V source is not in parallel with the 14 ohm resistor because of the 1.5 ohm resistor inbetween them.
  8. abettino
    Jan 12, 2012
    The voltages will not be the same. They are not at the same node.
