will the voltage affect the prop?
Discussion in 'The Projects Forum' started by ampere_elec, Sep 24, 2012.
  1. ampere_elec
    Sep 24, 2012
    Hi there, this is my first thread, I'm new too electronics but know the basic due to my knowledge of electrical workings, anyway my question is, I have a motion dectector kit that runs off a 12v supply and a Halloween prop that runs off 3x AA batteries the prop had a rubbish sound activated trigger, I want to replace the sound active trigger with the sensor but will the 12v supply give like a back feed into the prop, therefore affecting/activating the Halloween prop?
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    Let the motion detector fire a relay, then use the relay to switch the Halloween prop on /off
    ampere_elec likes this.
  3. wayneh
    Sep 9, 2010
    12,406
    3,256
    If you could force the prop into an always-on state, then you could probably control it with power on/off with the motion detector.
    Otherwise, hacking one sensor in place of another requires seeing the schematic and/or circuit boards. It may be easy to do, but not blindly.
