Will LCD present in mobile phones affect the radiation pattern of the antenna?
Discussion in 'General Electronics Chat' started by jvsharath, May 15, 2009.
  1. jvsharath
    May 15, 2009
    Hi All,
    I want to know whether the radiation pattern of an antenna in a mobile phone affected by LCD (present in the phone).
    If you can suggest any application notes or any site it will be very useful for me.
    thanks in advance.
  2. Von
    Oct 29, 2008
    Not sure of the context of your question but the short answer is yes.
    The antenna engineer works to optiimze radiated performance for a given spectrum, form factor, and composition while at the same time trying to reduce the amount of radiation absorbed by the user, the so-called SAR or specific absorbtion rate.
    Once the design has been finalized any changes can effect RF performance, SAR, battery life, bit error rate, etc.
    If you are contemplating removing the LCD from your phone you will effect the performance but not necessarily such that you could tell due to network capabilities. You may however increase the SAR as the LCD may be employed as a shield of sorts.
