Will I need a shunt for this ammeter?
Discussion in 'The Projects Forum' started by Keith Robinson, Dec 5, 2014.
  1. Keith Robinson
    Nov 30, 2014
    41
    I would like to put a volmeter and ammeter on the output of my Variac and Im fairly sure my ammeter will need a shunt but I cant seem to figure out what size shunt Ill need, or if I could make one if i do need one. Perhaps the icons on the face of the meter might hold some info. could anyone enlighten me please?
    thanks
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    It looks to me that your meter is 400mA AC Full-scale. I have never tried to put an external shunt on an AC ammeter. Because of the non-linearity due to the rectifier inside it, I'm not sure how to go about it...
  3. Keith Robinson
    Nov 30, 2014
    41
    so perhaps it doesnt need and external shunt then? I didnt want to fry the thing by just putting it in series with the load
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Should work as long as your load draws less than 400mA AC. Even a 100W lamp would draw more than that...
  5. Keith Robinson
    Nov 30, 2014
    41
    oh right! looks like Ill need a larger meter, or only use it for low power running. Thanks for your help. As you might guess Im very amateur but trying to teach myself. I hate asking for help, but this site is really freindly and helpful.
    thanks again. Keith
  6. mcgyvr
    Oct 15, 2009
    4,798
    979
    Never seen an simple ammeter that didn't need a shunt..
    But I've also never used an ammeter that didn't go into a system with the capacity for hundreds of amps.
  7. Kermit2
    Feb 5, 2010
    3,858
    968
    the simple ammeter is actually a milli-volt meter which measures the voltage dropped across a shunt resistor, through which, a majority of the electric current passes. it is the shunt resistor which turns the voltmeter to ammeter. small ones have the shunt inside and large value meters have external shunts.
    a series resistor just turns the same simple milli-voltmeter into a voltmeter for a larger/higher voltage range.
    For AC use insert a bridge rectifier/(iron vane meters are better in AC)
    About the OP's picture of his meter.
    Looks like it might be based on a very old type known as a heated filament type ammeter. If OEM and from the teens to the fourties it could be worth more on ebay than on a hobby project.
  8. Keith Robinson
    Nov 30, 2014
    41
    Thats the lesson Ive learned here, - use an ammeter with enough capacity to cover whatever might be being measured. especially when dealing with AC. A DC ammeter could be used with the correct resisive shunt in place, in parallel
    thanks for your comments.
  9. Keith Robinson
    Nov 30, 2014
    41
    Thank you very much for your excellent explanation, I really think Im starting to get it now! Im collecting a few of these old meters as I love the old technolgy. Ive managed to get one or two quite cheaply from ebay. some of the workmanship is outstanding. Ive restored a couple and am hoping to use them in my simple steampunk projects. the brass one must be getting on for a hundred years old and the workmanship is superb.
    thanks again for your great answer about ammeters regards Keith
  10. Keith Robinson
    Nov 30, 2014
    41
    Hi Nandu, thanks so much for your response, things are a little clearer to me now. Kermit2 explained it so very well, and with your response the fog is clearing! I'll refer back to this about impedance and resistance when I know a bit more (hopefully!) Its interesting to see that this particular meter is a Moving Iron meter. perhaps that was depicted in the symbols on the dial? kind regards Keith
  11. Keith Robinson
    Nov 30, 2014
    41
    this is my variac Im trying to upgrade with better meters
  12. Johann
    Nov 27, 2006
    190
    30
    A variac is one of the most useful pieces of equipment! I shall never part with mine!
    Keith Robinson likes this.
