Will I deplete my battery fast if I make a magnet?
Discussion in 'General Electronics Chat' started by Yaşar Arabacı, Nov 14, 2014.
  1. Yaşar Arabacı
    Nov 11, 2014
    32
    I want to try wrapping cables around a steel bar and connecting 9V battery to it in order to experiment with electro-magnets. Should I be connecting some resistance to cable or does making an electro-magnet act like a resistance in the circuit?
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    A 9V battery cannot provide a lot of current.
  3. Yaşar Arabacı
    Nov 11, 2014
    32
    Do you mean I won't see the effects of magnetism even without using any resistor? How many amps do I need in order to observe the effects of electromagnetism? I have a feeling that 220V AC 50Hz would be too much of a current to play with.
  4. ISB123
    May 21, 2014
    1,240
    531
    You are basically short circuiting the wire its going to get very hot.You can use 4x1.5V AA batteries to play with small electromagnets.
  5. joeyd999
    Jun 6, 2011
    2,756
    2,916
    I think you can get many amps for a short time (seconds?) via a dead short across a new 9V Alkaline. It won't last long, though, and it will get hot.
  6. joeyd999
    Jun 6, 2011
    2,756
    2,916
    Get yourself some fine magnet wire and run *lots* of turns. You can compute the DC current by measuring the DCR of the coil, and dividing that into the battery voltage. The higher the coil resistance, the longer your battery will last.
  7. BobTPH
    Jun 5, 2013
    806
    121
    I have actually put a multimeter on the 10A scale across a new 9V and it only gave about 1.5A.
    Edit:
    Magnetic field = Current x turns.
    To get a good magnetic field from a 9V, put many many turns. Enough to create a resistance of about 18 Ohms, and it will draw 500mA, and be dead in less than 1 hour.
    Bob
  8. joeyd999
    Jun 6, 2011
    2,756
    2,916
    I just got 2.3A off a new Duracell.
  9. ISB123
    May 21, 2014
    1,240
    531
    If you want you could buy 12V/3A transformer since those are pretty cheap and then make a simple power supply using rectifier bridge and a capacitor.
    You cant use voltage regulators since they have short circuit protection and will over heat and die.
  10. Yaşar Arabacı
    Nov 11, 2014
    32
    I made a coil that created a resistance of 1 ohm and it drew 750mA current, but I didn't see any magnetism. I will try later with better equipment.
    I guess my battery is about to be depleted :)
  11. ISB123
    May 21, 2014
    1,240
    531
    Wire needs to be isolated it cannot be bare.
  12. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The only thing a resistor will do is waste some of the power as heat.
    If you're using a PP3 type 9V battery - they're amongst the lowest energy density batteries you can get.
    Do a search for; "ampere-turns" - every turn of winding you put on has its magnetic field around it and contributes to the whole.
  13. BobTPH
    Jun 5, 2013
    806
    121
    Tell us about your coil, what kind of wire, how many turns, and what the core is made of.
    Bob
  14. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Try using an automotive battery, more current available.
    Max.
  15. alfacliff
    Dec 13, 2013
    2,449
    428
    soft iron works best for that. hardened steel has different characteristics. I agree, more turns of fine wire, like #26 or so. a heavy cable will have way too little resistance to limit the current, and if you use a resistor, the current will be too low for the ampere turns.
