Will a glass housing affect a transmitter signal from reaching a receiver
Discussion in 'The Projects Forum' started by Cris909, Jul 22, 2014.
  1. Cris909
    May 4, 2014
    28
    Does anyone happen to know if a transmitter would have any trouble sending a signal to a receiver in a glass housing enclosure?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What frequency?
  3. Cris909
    May 4, 2014
    28
    I'm using the xbee pro. 802.15.4 I believe
  4. Cris909
    May 4, 2014
    28
    Actually the frequency is 2.4GHZ
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    no it would not. only conductive materials or extreme thickness of non conductors will stop the signal.
    Cris909 likes this.
  6. sirch2
    Jan 21, 2013
    1,008
    351
  7. wayneh
    Sep 9, 2010
    12,379
    3,232
    Anything other than vacuum will absorb some of the signal and decrease the effective range. The question is how much. A little glass might only subtract a few percent (that excellent reference from sirch2 may give a better estimate), so it would only be a problem if you were already on the bleeding edge of the range.
  8. Lestraveled
    May 19, 2014
    1,957
    1,217
    The dialectic coefficient of velocity of glass can act as a lens that will change the radiation pattern of your transmitter. Glass is not transparent at RF frequencies, it is a delay line and a attenuator.
    Simple answer: Try it, analysis is way to complex for this thread.
    Mark
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The type of glass will also have a great influence on the attenuation.
    There is glass that contains a lot of lead.
    This type of glass is used in x-ray equipment to stop the x-ray radiation going outside the cabinet.
    Bertus
    Cris909 likes this.
