Wig Wag on 12v with Leds 5mm
Discussion in 'The Projects Forum' started by Sasoriza, May 5, 2013.
Thread Status:
Not open for further replies.
  1. Sasoriza
    May 5, 2013
    Ohayou, Hi, Allô circuitians people
    First of all, I am using Tina Pro (industrial version 7.0.20 SFDS) and I am here to ask you if someone can help me to understand or to know how I can make my own wigwags on 12v, using ((24 (+3) leds) x 4 = 108 leds) of 5mm. To be honest, I am making an amateur movie (kind of paranomal things) and I have my own Crown Victoria 2004.
    Since 1 month ago, I am looking for some wigwag prefab-modulars on internet but I do not need what vendors are selling ; I mean, Nigth Club effects (30 modes) knowing there are just 4 modes I need (on them) or strobe light effect with lamp (as a lift tractor (?)) and I do not want to buy any Whelen System (I have some problems with sendings-receptions)...
    Also, 2 weeks ago, I buyed a kind of modular (12v) using 22 Leds (blue, red (red leds of 3mm are death already)) but the modular has just 3 modes :
    L = left leds (blue) --- R = right leds (red) :
    - Cycle I : L-L-L-L.....R-R-R-R (4 msec (very fast))
    - Cycle II : L.....R.....L.....R (0.5 sec (alternative school bus))
    - Cycle III : LR....LR.....LR....LR (1 sec (same time - hazard position))
    To have an idea of what do I want, I drew a scheme on Tina Pro (a copy of a torshlight I buyed) an I have made 8 different flash modes (Gif Anim) to show you. I can not to tell you more because I do not know how things work but I think you have a global idea of what I am looking for...
    • The Scheme :
    (click to enlarge)
    • The torshlight I buyed at 3.49 $ (circuit showed (left) and mounted (right) :
    (click to enlarge)
    PS. Leds number 25-26-27 are already on my circuit (related with 2 external wires) but I want to use them on each side of my plate.
    • My 8 gif anim flash modes (maybe more to come) :
    http://www.internet-underground.org/lerx/public/strobes/X.html
    • Good to know :
    Here are the infos of my "futur" LEDs I would like to buy. I am not sure about TEMP and INTensity because I do not know what all that means :
    White (water clear)
    • 12v, 5mm
    • Temp : 5000°k
    • Int : 15000 mcd
    • Amp : 20mA
    • Angle : 15°
    • Cons : 120 mW
    • Tens : 3.2-3.4v
    • Life : 80 000 hrs
    Blue (water clear)
    • 12v, 5mm
    • Temp : 470°nm
    • Int : 11000 mcd
    • Amp : 20mA
    • Angle : 15°
    • Cons : 120 mW
    • Tens : 3.2-3.4v
    • Life : 80 000 hrs
    Red (water clear)
    • 12v, 5mm
    • Temp : 625°nm
    • Int : 7000 mcd
    • Amp : 20mA
    • Angle : 15°
    • Cons : 100 mW
    • Tens : 2.0-2.4v
    • Life : 80 000 hrs
    Yellow (water clear)
    • 12v, 5mm
    • Temp : 590°nm
    • Int : 14000 mcd
    • Amp : 20mA
    • Angle : 15°
    • Cons : 100 mW
    • Tens : 2.0-2.4v
    • Life : 80 000 hrs
    Are there any hopes to realise what do I want ? If a Patron Saint of the impossible is still alive to help me, I will pray for him/her... If you have some other ideas for better LEDs infos and/or modes, I will take them all and and if I am not enough clear with all this, I will try to explain much better next time "(^.^)"
    PS. If there are any costs of time (and/or energy), I will pay...
    Arigatougozaimasu, Thank you very much, Merci beaucoup
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
    Meixner likes this.
Thread Status:
