I am trying to simulate and then breadboard a simple Wien oscillator.
I want to use this to drive an 8Ohm speaker to generate an audio beacon
signal. 3 circuits were simulated in LTSpice using a UA741 (because I
have these at hand) and diodes/zeners for stabilization. I have set the R
and C values for +/- 1KHz.
When performing the simulations I get the expected output sine wave
(with the distortion of course) but don't understand the amplitudes I get.
To be concrete I have tested:
1. Wien oscillator with no stabilizing elements powered with +5V and -5V.
I get a clipped sine-like wave as expected with a positive amplitude of
3V and negative 3V.
2. Wien oscillator with 2 diode stabilizing elements powered with +5V and
-5V. I get a sine-like wave as expected with a positive amplitude of
about 747mV and same negative value.
3. Wien oscillator with 2 zener stabilizing elements powered with +12V and
-12V. I get a sine-like wave as expected with a amplitude from
-10V to +10V.
I do not understand amplitudes in cases (1) and (2). In case (1) I
expected a sine wave with a p-p amplitude of 10V but get 6V. In
case (2) I expect a p-p amplitude of 12.4 (zener breakdown of 6.2).
Can anyone explain this?
I have added simulation (2) and (3). Simulation (1) is simulation (2)
with the diodes remove.
TIA.
3V and negative 3V.
-10V to +10V.
TIA.
