Wien Bridge Oscillator
Discussion in 'The Projects Forum' started by RINCY, Mar 7, 2012.
  1. RINCY
    Mar 7, 2012
    i need info regarding the components required to mount a Wien Bridge Oscillator using bjt its my mini project
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Can you post a schematic of the intended circuit?
    Bertus
  3. #12
    Nov 30, 2010
    16,663
    7,310
    Maybe this will help.
  4. Blofeld
    Feb 21, 2010
    82
    18
    Is there a special reason why you want to use transistors ? If not, you might consider to use a good audio op amp instead - you can achieve lower distortion. The attached file by #12 shows some examples.
    Also AN 43 "Bridge Circuits" by Jim Williams, discussion of Wien bridge oscillators starts on p.29:
    http://cds.linear.com/docs/Application Note/an43f.pdf
