Wien Bridge Oscillator
Discussion in 'Wireless & RF Design' started by nerdegutta, Oct 28, 2010.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    806
    Hi.
    I'm just wondering... The Wien Bridge frequency formula, according to Wikipedia, is:
    f=1/2∏RC
    so, if I use a 1M resistor and a 0,1F capacitor:
    f = 1 / 2 x 3,14 x 1 000 000 x 0,1 = 628 000 Hz / 1000 = 628KHz
    Is this correct?
    And am I able to use this in a RF transmitter circuit?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Actually it's 1/(2∏RC) - so your values would give 1.59Hz.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
  4. nerdegutta
    Dec 15, 2009
    2,565
    806
    Nice! Thanks!
    I will read...
    Is it possible to use this type of oscillator in a RF transmitter circuit. What kind of oscillators is best in RF. Wien-Bridge, Hartley or Colpitt's? The frequency is in the 500 - 1600 KHz range.
    I am kind of hoping the Wien-Bridge, because I'm struggling with the air-core coils. :(
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    The Wein bridge probably wouldn't be the best choice - I've not seen in used in conventional RF circuits. However the link I gave does suggest stable operation above 1MHz is possible with the right components.
    What do you actually want to do? There may be laws in your country which limit the permissible power output from an oscillator radiating in the AM band.
  6. nerdegutta
    Dec 15, 2009
    2,565
    806
    Yes, I know. There are regulations. I'm just trying to learn about RF, oscillators and transmitters.
  7. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  8. nerdegutta
    Dec 15, 2009
    2,565
    806
    I'm currently reading:
    "RF Components and Circuits", by Joseph Carr. There he is not mentioning the Wien Bridge. I thought that this oscillator would be easier to build, without the home-made coil.
    I have succssfully built a small FM transmitter, but the frequency is a bit unstable. And my first guess is the coil. (The range is about 100m)
    That's why I'm interested in the Wien Bridge.
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Here is an example of an 1 Mhz wien bridge oscillator:
    http://www.jensign.com/wien/index.html
    The circuit build on a breadboard will give more trouble than on strip- or veroboard.
    Bertus
  10. skeptic
    Mar 7, 2010
    51
    9
    Why don't you look into crystal oscillators like the Pierce?
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Air cores are generally not the problem, since they aren't affected by temperature. Solid state devices in general are the culprits there.
    You must have a really stable power supply voltage with lots of noise bypass (capacitors). This is a given, and much more likely to affect frequency stability. Simple three terminal voltage regulators, or even zener diodes, are your friend.
    If it is a permanent project, putting it in a metal box is always a good idea for the final layout.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
  13. nerdegutta
    Dec 15, 2009
    2,565
    806
    Skeptic:
    This is kind of what I was hoping would show up. Thanks.
    Bill_Marsden:
    I thought it was my coils. I've read alot, and I've worked my way thru different calculators. It seemed to me that I could not get the diameter, length and number of turns right.
    Regarding the powersupply. At first I tried with a "jump-started" ATX PC powersupply. This didn't work very well. Lots of noise or something.
    Then I tried with a 9v battery. This was much better. Maybe I should use a LM7805 and some capacitors? Never thought of that. Thanks.
    t_n_t:
    Thanks for the link. I will read.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you have stiff wire coils are easily adjustable, by the simple expedient of spreading the coils apart (very carefully, very slightly) or compressing them together. The formula's get you in the ball park, but fine tweaking is an art.
  15. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  16. nerdegutta
    Dec 15, 2009
    2,565
    806
    That is true. I usually wrap wire in the threads of a bolt. After that I carefully "un-screw" the bolt. That leaves me with a somewhat nice coil.
    Thank you for the links, Bertus. I guess you have a link for nearly everything. :)
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    A bolt? Hopefully you don't leave the bolt in place. The core dramatically affects frequency responses (which is why air is so popular).
  18. Kermit2
    Feb 5, 2010
    3,851
    966
    Freq drift and stability over short duration time spans(surge and sag) can be a problem in LRC component oscillators. Depending on the application, crystal control, or Digital PLL control, may be the only way to get acceptable transmit and receive frq stability.
  19. nerdegutta
    Dec 15, 2009
    2,565
    806
    Bill_Marsden:
    I remove the bolt, so I end up with an Air Core Coil...
    Kermit2:
    Where do I find information about Digital PLL? Do you have some good links or ... Ah... I know "Google it." :) I will.
    Thanks!
