width considerations for MOSFET switch
Discussion in 'General Electronics Chat' started by arunkps, Feb 12, 2014.
  1. arunkps
    Jan 28, 2014
    16
    What are the Width Length design considerations for the switch MOSFET (PMOS or NMOS) in synchronous buck converter?
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Odd question. Are you really asking about the physical size of the device?
  3. tshuck
    Oct 18, 2012
    3,531
    675
    ...or are you referring to the channel dimensions used in the semiconductor?
  4. mcgyvr
    Oct 15, 2009
    4,794
    978
    or maybe PCB trace/track width/length considerations?
    tshuck likes this.
  5. ScottWang
    Aug 23, 2012
    4,934
    777
    Probably you are asking about the heat sink for the MOSFET, if the answer is yes then what are the W/V/I?
  6. mcgyvr
    Oct 15, 2009
    4,794
    978
    "size doesn't matter" :)
  7. GopherT
    Nov 23, 2012
    6,339
    4,092
    It's funny that the big MOSFETS never say that, just the small ones.
  8. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Nice to see the originator of this thread hasn't even bothered to come back and ask a sensible question.
  9. ScottWang
    Aug 23, 2012
    4,934
    777
    Why you said that nice to see the OP ...
  10. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Ironic .
  11. arunkps
    Jan 28, 2014
    16
    Sorry, for the delay and it is because of my internet problem. Meanwhile, people presumed about my absence.
    Ok, here I give the detail. Basically I am designing a synchronous buck converter and have planned to do a layout in 180nm in Cadence. Initially, when I simulated a simple buck converter power stage in Cadence, I faced problem in the switching section i.e., both HSS (High Side Switch) and LSS (Low Side Switch). So when I tried to simulate a MOSFET (PMOS or NMOS) alone, I noticed that the MOSFET not acting as switch until I increased the width of the MOSFET to enormous value (100um). It is my understanding from the simulations; that inorder to act the MOSFET as switch, the width should be made very large such that the ON resistance become very small and the VDS ON will be very less and the complete input voltage can be seen at the output of the MOSFET.
    My simulations files are there for your reference. However the simulations are of the asynchronous buck converter.
    The designed component values are for the spec
    vin=1.8v
    vout=500mv
    Load current=1mA
    switching frequency=1MHz
    output Iripple=100uA
    Output Vripple=500uv
    Please help me in simulating this power stage.
  12. arunkps
    Jan 28, 2014
    16
    Ok, here I give the detail. Basically I am designing a synchronous buck converter and have planned to do a layout in 180nm in Cadence. Initially, when I simulated a simple buck converter power stage in Cadence, I faced problem in the switching section i.e., both HSS (High Side Switch) and LSS (Low Side Switch). So when I tried to simulate a MOSFET (PMOS or NMOS) alone, I noticed that the MOSFET not acting as switch until I increased the width of the MOSFET to enormous value (1000um). It is my understanding from the simulations; that in order to act the MOSFET as switch, the width should be made very large such that the ON resistance become very small and the VDS ON will be very less and the complete input voltage can be seen at the output of the MOSFET.
    vin=1.8v
    vout=500mv
    Load current=1mA
  13. crutschow
    Mar 14, 2008
    13,523
    3,392
    What type of help do you need with the simulation?
  14. arunkps
    Jan 28, 2014
    16
    I am not getting the desired 500mv output voltage.
  15. crutschow
    Mar 14, 2008
    13,523
    3,392
    Output voltage on which schematic? Show us the voltages at all the nodes.
  16. arunkps
    Jan 28, 2014
    16
    Attachment in the buck converter circuit. I have designed the component values to get Vo of 500 mv. I will be thankful, if you can simulate it in 180nm (preferably CADENCE).
