Widlar Circuit equation
Discussion in 'Homework Help' started by black_bear, Apr 14, 2010.
  1. black_bear
    Apr 14, 2010
    I have the following equation from a widlar circuit:
    Vt[ln(.9927) -ln(Iout)] = 700(Iout-1)
    Vt = 26mV
    I(in) = 0.9927 mA
    R in the circuit = 700 Ohms
    I had a third transistor with V(be) ON = 700mV
    Can someone help me find I(out)
  2. syed_husain
    Aug 24, 2009
    61
    5
    as you know this type of equation is transcendental equation, u cant solve this like normal polynomial equation. if u want to do it manually, u have to use NEWTON's mehtod. it is an iterative process (quite tiresome:(). do some research u will able to figure it out.
    here i calculated the value of Iout using Mathemtica.
    NSolve[26*10^-3 (Log[0.9927*10^-3] - Log[Iout]) - 700 (Iout - 1) == 0,
    Iout] // N
    Iout-> 0.999743 A.
    hope this will help.
  3. black_bear
    Apr 14, 2010
    Hello Syed
    (AoA)
    Thanks for the reply but unfortunately the answer to this problem is one of this 5 choices: I(out) equals
    1. 0.2 mA
    2. 0.5 mA
    3. 1 mA
    4. 1.7 mA
    5. 3.2 mA
    I think I have not set-up the equation properly. Please see the attached circuit diagram.
    WaS
    Faisal
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    As a rough guess I'd say it's going to be about 1mA.
    I2*R2+VBE2=VBE1+VBE3
    If VBE1≈VBE2≈VBE3=0.7V
    I2≈0.7/700=1mA
    A more careful analysis is difficult for me due to the presence of Q1.
    If Q1 was omitted then normally one might try a closer solution using the relationship -
    I2=(Vt/R2)*Ln(I3/I2)
    - which is solved iteratively. I3 is the Q3 [&Q1 when included] emitter current which you work out as indicated in your analysis.
    An better 'approximate' guess with Q1 included might be obtained using
    I2=VBE1/700+(Vt/700)*Ln(I3/I2) - again solved iteratively
    I3 would be about 1mA (depending on your assumed VBE's for Q1 & Q3 - which I took as 0.65V)
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    It's possible with the selected transistor that VBE at 1mA could be a lot less than 0.65V - perhaps as low as 0.57V
    In this case the current in Q1 & Q3 [I3] would be approx 1.01mA.
    The approx estimate for the resulting Q2 current would be determined from
    I=0.57/700+(Vt/700)*Ln(1.01e-3/I) where Vt=26mV
    When solved iteratively this would give
    I=822uA.
    Which isn't far removed from I=VBE/700=0.57/700=815uA.
    So the iterative method in this case doesn't add much to the most basic & simpler solution.
