hi,
I've been asked to design a project for the university, unfortunately I'm running out of time.
the project is:
Design a two-stage amplifier using either bipolar or FET transistors or a combination of both. You will have to select suitable transistors capable of, providing a voltage or a power gain of at least 100dB and covering frequencies from 100Hz to 1MHz. you are also required to simulate the amplifier operation and it's frequency response including the 3-dB bandwidth. Explain each step in the design and with your results and plots.
Note: You are free in your selection of the transistors and the bias rails and may add a buffer stage if required. Also, you must site all references used in the design process.
I'm running out of time and i need any possible help from you guys, please if you can provide me with any useful information.
thanks in advance
you can contact me using either my e-mail or my BlackBerry
e-mail: <SNIP>
BB pin-code: <SNIP>
the project is:
thanks in advance
e-mail: <SNIP>
BB pin-code: <SNIP>
